Browse Forums Heating, Cooling & Insulation Re: Speedheat vs other heating methods 6Jun 03, 2010 9:44 pm I'm surprised that Speedheat can't give you an answer. i assume it's because the heating is not often used under floorboards. We are installing it next week under stone tiles. i'm pretty sure it only gets to about 35 degrees c so i'd be surprised if it damaged anything. Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3497 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9874 Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4870 |
