I've got a large in-line fan in my roof, bolted down directly to a timber plank sitting on the trusses. That fan vibrates quite badly and I'm after some advice for fixing that. Any recommendations for mounts, mats, etc ??
Chris
Browse Forums Heating, Cooling & Insulation 1 Apr 30, 2010 3:15 pm I've got a large in-line fan in my roof, bolted down directly to a timber plank sitting on the trusses. That fan vibrates quite badly and I'm after some advice for fixing that. Any recommendations for mounts, mats, etc ?? Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Fan Vibrations 2May 01, 2010 9:20 am kristofw I've got a large in-line fan in my roof, bolted down directly to a timber plank sitting on the trusses. That fan vibrates quite badly and I'm after some advice for fixing that. Any recommendations for mounts, mats, etc ?? Chris Firstly I'm wondering if the fan is vibrating badly because it's badly balanced or has a manufacturing fault. Even a bent or damaged fan blade could cause significant vibrations. If the fan is operating within the specifications you could try various methods of isolating the fan unit vibrations from house frame. I've seen in roof air conditioner units sitting on waffle pads and suspended from the upper roof trusses by steel cables with isolation springs. If the vibration is severe or you wanted to bolt the unit down more securely you could use some stationary engine vibration mounts similar to car engine mounts. The link below is just an example of what might be available. www.fdrive.com.au/products/04/engine.php I'd also try talking to local air conditioner installers and suppliers (someone like www.airwaresales.com.au/) as they might be able to help. My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5132 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1228 |
