Browse Forums Heating, Cooling & Insulation Re: damp under house 3Apr 23, 2010 1:04 am yep treat the cause not the symptom Where you are coming from is where you are going to... Re: damp under house 4Apr 23, 2010 6:59 pm Yes, already explored this aspect...cant change a poorly built house on a sloping block , wedged in tightly between two adjoining homes...no clearance under floor joists, placed on brick stumps with joists and bearers directly contacting damp masonry....I need ventilation but minimal clearance doesnt allow for more vents...more air is needed to circulate Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20580 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7788 Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 6342 |
