Browse Forums Heating, Cooling & Insulation 1 Apr 20, 2010 11:14 pm Seems a 6 star requirement for new buildings comes in to effect on 1st of May 2011 in Victoria. Does anyone know when does a newly constructed building need to comply with this code? E.g. on contract date, occupancy date or something else? Built a 2 storey house... hebel, proctor, pvc windows, aiphone, deck roofs, louver covered patio Re: 6 star code in Vic - at what stage is it considered ? 2Apr 20, 2010 11:29 pm Our build is currently 6 stars due to having all double glazed windows. But we did pay heaps for it I can only imagine build price will now go even higher. I would guess that it's construction date as if you already stated a build it would be hard to 6-star it half way through. Found this http://hia.com.au/hia/content/Builder/r ... iency.aspx Quote: Each State and Territory has slightly different regulations about when these changes will apply. In most instances, the changes will apply to any building application lodged on or after the start date. However, some states have transitional periods, so you should check with HIA or your local council. So it's when you lodge your application. Re: 6 star code in Vic - at what stage is it considered ? 3Apr 20, 2010 11:35 pm fruitty Our build is currently 6 stars due to having all double glazed windows. But we did pay heaps for it I can only imagine build price will now go even higher. I think you will be 7 or 8 stars... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: 6 star code in Vic - at what stage is it considered ? 4Apr 21, 2010 12:58 am Rudy Seems a 6 star requirement for new buildings comes in to effect on 1st of May 2011 in Victoria. If you are really interested in building an energy efficient house based on sound principles rather than just following a tick a box then read this initiative sponsored by the Federal Government. Your Home - Technical manual There are similar information sites for most states and territories. Re: 6 star code in Vic - at what stage is it considered ? 5Apr 21, 2010 9:58 am Good link Dymo I have said many times that a star rating falls over quickly if the numbers are rubbery. I don't think the cost of building a higher rating house should be more expensive to do. ...since there is a lot of construction cost in the standard home. A shift in the style of homes built could make them cheaper not more xE. But on consideration, sadly You are probably right as it seems we are becoming more and more profit motivated. Where you are coming from is where you are going to... Re: 6 star code in Vic - at what stage is it considered ? 6Apr 21, 2010 10:02 am I was under the impression that our estate HAD to be 6 star, turns out it was just suggested (too late as we already had our house to 6 star). Double glazed windows for us only cost an extra 4k for the whole house (41sq). It's not that bad when you consider the benefits. Our house thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=18335 Re: 6 star code in Vic - at what stage is it considered ? 8Apr 21, 2010 11:41 pm borg In answer to rudys question. It is on the day you permits get approved. Thanks for that. If the event is "permits approval" that is a very early stage in the construction process... BTW, I should have been a bit clearer in my question - I was trying to get a feel if it would make sense to time signing up with a project builder to get 6 stars by default and what the timing would needed to be like. Built a 2 storey house... hebel, proctor, pvc windows, aiphone, deck roofs, louver covered patio Re: 6 star code in Vic - at what stage is it considered ? 9Apr 25, 2010 12:34 pm There are a number of volume buidlers already selling 6 star plus homes for little or no additional cost!! Check out the futures range by Burbank or some of the homes by JG King!. Cheers. Re: 6 star code in Vic - at what stage is it considered ? 10Apr 25, 2010 12:42 pm estevens There are a number of volume buidlers already selling 6 star plus homes for little or no additional cost!! Check out the futures range by Burbank or some of the homes by JG King!. Cheers. Just for reference, steel frames are not considered in FirstRate, and they most certainly bridge the insulation layer. JG King uses steel frames. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: 6 star code in Vic - at what stage is it considered ? 11Apr 25, 2010 8:25 pm ed @ EcoClassic and they most certainly bridge the insulation layer. I guess that's a bad thing, decreasing the effect of the insulation yeah? Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8462 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 |
