Browse Forums Heating, Cooling & Insulation 1 Mar 22, 2010 8:14 pm HI, I am moving toward installing ducted natural gas heating. Reading through the forums has been really helpful. I still have a basic question about noise. How noisy are these things? I have the option of underfloor or external installation. What would you recommend? Do brands vary re noise levels. I'm sure you get the drift of my questions. Cheers Cav Re: Noise level of ducted gas heating 2Mar 23, 2010 7:48 am there usually in a spot where the noise won't affect you, and if it does, it would be minimal. That was the case with my friend's old one anyway. If you have it externally - even less noise! Underfloor, perhaps more warmth as it enters into the house direct? Re: Noise level of ducted gas heating 3Mar 30, 2010 6:22 pm In our old house we had ducted gas heating installed and it was one of the best things I ever did I love walking into each room knowing it will be the same temp. Our unit that ran it was outside and was a little noisy when it started up, only if you were outside though, you couldn't hear it inside. Our ducts were in the floor too which was great for drying washing in the cold weather! If you get it, you'll never look back Bek I'm back Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11795 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11666 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 |
