Browse Forums Heating, Cooling & Insulation 1 Mar 06, 2010 7:19 pm What ceiling fans are required? Look there are stacks of fans on the market, some have 4 blades, some have 3. Some hang close to the ceiling, others don't. Some have wall mounted controls and others have remote. Some are small, some are large. How the hell do I work out what fan type the room needs? Re: Ceiling fans 2Mar 06, 2010 7:59 pm My understanding is the blade length is more important than blade number. Longer blades move more air for a given rpm and as a result are less noisier. Note how efficient wind farm turbines are with only 3 long blades. A reasonable gap should be between the fan and ceiling to allow smooth air flow. I have read that one foot minimum is recommended. There are various blade designs to try to improve air flow for a given energy input. In my research I found these ones but unfortunately locate them in Australia. They claim to be twice as efficient due to blade design. Development of an Enhanced Ceiling Fan: An Engineering Design Case Study Highlighting Health, Safety and the Environment Gossamer Ceiling Fans Metal blades are said to be a little noisier than wooden ones because they don't flex as much. It doesn't seem to be problem for us unless if they a going full bore. Some fans have 'winter' settings to reverse blade movement to move air upward rather than producing an uncomfortable breeze. Note that noticeable air movement drops off quite rapidly beyond the perimeter of the blade tip. Re: Ceiling fans 3Jul 26, 2010 5:39 pm I concur completely with all that dymonite69 wrote in this thread. Numbers of blades is far less important than the other factors listed so thoroughly in that post. If "performance" were the only consideration then our choices would be a lot easier. Other factors like "Appearance" & "Price" are strong determiners for choosing a fan and "Performance" unfortunately becomes important after the "good looking, cheap" fan doesn't meet the purchaser's performance expectations. As in most product selections when considering Performance, Appearance & Price - there is a trade off. If a low price is the major consideration then something else is going to give way. In choosing a good fan: 1. ask about a reputable brand 2. find a design in that brand that appeals to you 3. ask about its performance characteristics 4. shop it around to get the best price Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10684 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 |
