Browse Forums Heating, Cooling & Insulation Re: When to install ducted air conditioning and central gas 2Mar 03, 2010 10:40 am When they are framing they'll need to know what allowances to make for ducting - I thought it definitely should have been taken care of when drawing your plans. Are you getting the builder to supply and install or just duct? PM Nav - he was looking at getting gas heating After 4 years - we're in! Re: When to install ducted air conditioning and central gas 3Mar 04, 2010 8:08 pm stonecutter1309 When they are framing they'll need to know what allowances to make for ducting - I thought it definitely should have been taken care of when drawing your plans. Are you getting the builder to supply and install or just duct? PM Nav - he was looking at getting gas heating I need an external company to supply and install - the builder has made allowances for this already Re: When to install ducted air conditioning and central gas 4Mar 05, 2010 6:33 am If your builder has already made allowances and is doing ducting - then I suppose you can get quotes whenever you like. But you won't be able to install until after handover. Try sending Nav and PM - he did that. After 4 years - we're in! Re: When to install ducted air conditioning and central gas 5Mar 05, 2010 8:10 am stonecutter1309 If your builder has already made allowances and is doing ducting - then I suppose you can get quotes whenever you like. But you won't be able to install until after handover. Try sending Nav and PM - he did that. Nav tells me he has decided to get a reverse cycle air conditioner instead. Is there much difference in getting central gas heating + reverse cycle air conditioner (original plan) or one of those add-on air cond on the central gas heating? Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8996 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
