Browse Forums Heating, Cooling & Insulation Re: Bradford EnviroSeal Wall Wrap Vs Wall Breather 2Feb 09, 2010 5:54 pm Wall breather is used for applications such as foam cladding or hebel / blueboard cladding, normal wall wrap is fine for brick veneer and other cavity methods. Have a look on the website it should explain it, what material are you using?? Re: Bradford EnviroSeal Wall Wrap Vs Wall Breather 3Feb 09, 2010 9:15 pm hunts01 Wall breather is used for applications such as foam cladding or hebel / blueboard cladding, normal wall wrap is fine for brick veneer and other cavity methods. Have a look on the website it should explain it, what material are you using?? Thanks for that. We are doing brick veneer. Ended up purcasing wall wrap Vapour permeable wraps are recommended for any climate and main think it is allow walls to breath (i.e. remove water vapour) while at the same time, providing protection… 4 9780 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11273 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17047 |
