Browse Forums Heating, Cooling & Insulation 1 Jan 29, 2010 12:37 pm I have an unit that is 4 years old and on hot days it struggles to cool the house. It never used to. On a really hot day it trips the circuit break presumably beacuse it is drawing too much amps. What service can I do to maintain it? Re: Do ducted reverse cycle air con systems need regular service 2Jan 29, 2010 12:42 pm Spa Matz I have an unit that is 4 years old and on hot days it struggles to cool the house. It never used to. On a really hot day it trips the circuit break presumably beacuse it is drawing too much amps. What service can I do to maintain it? Get it serviced every year... more if you use it all the time... right now I'd have a look at the return air filter... Re: Do ducted reverse cycle air con systems need regular service 3Jan 29, 2010 6:18 pm Every year ideally, every second year at least. Clean return filter often - every three months is a great idea - the most likely source of issues if not done regularly. Re: Do ducted reverse cycle air con systems need regular ser 4Aug 04, 2010 12:37 pm Turns out one of the capacitors was blown in the main outdoor (2 fan) unit so that only one fan was running. It looked like both we running because one fan was creating suction to make the other one spin backwards. All fixed now Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6296 |
