Browse Forums Heating, Cooling & Insulation Re: Air-con - Get only ducting or get fully installed ? 3Jan 28, 2010 6:42 pm ... built a Promenade with Clarendon. viewtopic.php?f=31&t=25104 20-10-09 - excavation and piering completed ... 12-04-10 - Basins fixed. Connecting to the electrical grid 23-04-10 - PCI 07-05-10 - HANDOVER! Re: Air-con - Get only ducting or get fully installed ? 13Jan 29, 2010 6:15 pm Most installers will charge LESS during construction as certainly it is easier to run wiring and ducting with no plaster up. Yes, there may be more visits to the site, however most installers are doing more than one job in the construction area and it does allow the most efficient use of time. With that being said.....it also depends on how much your builder is whacking on top for his spending money. He most certainly won't be arranging it for nothing and some love to obtain their toys! How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5930 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
