Browse Forums Heating, Cooling & Insulation 1 Dec 03, 2009 6:30 pm Ive done a search, but cant seem to find the info Im looking for .. Is it possible to get refigerated cooling and ducted heating in seperate ducts? i.e. heating from the floor, cooling from the roof? Thank you! Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Separate ducts for heating and refrigerated cooling? 2Dec 03, 2009 6:35 pm That's what we currently have in our rented house. I dont think you'd be able to have a slab and ducted heating through the floor though - it would be a lot of work! You'd probably have to have your house on stumps. Re: Separate ducts for heating and refrigerated cooling? 3Dec 03, 2009 6:36 pm It will be Good to hear that someone has it! I couldnt find anything in my searches! They all say its an add on to the heating system Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Separate ducts for heating and refrigerated cooling? 5Dec 03, 2009 6:42 pm Bam It will be Good to hear that someone has it! I couldnt find anything in my searches! They all say its an add on to the heating system I thought it's evaporative that is used as an add-on? Isn't refrigerated another term for reverse cycle, which has both cooling and heating functions, or do they sell systems that only work in the one mode these days? Re: Separate ducts for heating and refrigerated cooling? 6Dec 03, 2009 8:19 pm Macy Bam It will be Good to hear that someone has it! I couldnt find anything in my searches! They all say its an add on to the heating system I thought it's evaporative that is used as an add-on? Isn't refrigerated another term for reverse cycle, which has both cooling and heating functions, or do they sell systems that only work in the one mode these days? I don't think I've seen an evaporative add on solution since they have to use seperate ducts. You can get refrigerative cooling with a gas heating add on though that uses the same ducts. In regards to having seperate ducts, it sounds like you might be in store for two seperate devices (a gas heater and a seperate refrigerative unit) which might make it more expensive - but it might also open up the oppurtunity to have gas heating + evap cooling, which will help balance out the cost again (and probably the most economical running costs). Re: Separate ducts for heating and refrigerated cooling? 7Dec 03, 2009 8:33 pm Sheepdog Macy Bam It will be Good to hear that someone has it! I couldnt find anything in my searches! They all say its an add on to the heating system I thought it's evaporative that is used as an add-on? Isn't refrigerated another term for reverse cycle, which has both cooling and heating functions, or do they sell systems that only work in the one mode these days? I don't think I've seen an evaporative add on solution since they have to use seperate ducts. You can get refrigerative cooling with a gas heating add on though that uses the same ducts. I think you might be right. Maybe I associated gas and evaporative because people who have gas heating seem to tend to add evaporative cooling later. I wonder how many different options are there? Re: Separate ducts for heating and refrigerated cooling? 8Dec 04, 2009 11:32 am Sheepdog Macy Bam It will be Good to hear that someone has it! I couldnt find anything in my searches! They all say its an add on to the heating system I thought it's evaporative that is used as an add-on? Isn't refrigerated another term for reverse cycle, which has both cooling and heating functions, or do they sell systems that only work in the one mode these days? I don't think I've seen an evaporative add on solution since they have to use seperate ducts. You can get refrigerative cooling with a gas heating add on though that uses the same ducts. In regards to having seperate ducts, it sounds like you might be in store for two seperate devices (a gas heater and a seperate refrigerative unit) which might make it more expensive - but it might also open up the oppurtunity to have gas heating + evap cooling, which will help balance out the cost again (and probably the most economical running costs). I assumed it would probably cost more.. Ill have to email some places and see whether its possible and what the price difference will be. And Hubby is set of refrigerated even though we'd originally planned for evap... So I think Ill need to get quotes on refrig/heating seperate, refrig/heating together and evap/heating. Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6544 Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4887 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10048 |
