Browse Forums Heating, Cooling & Insulation Re: ACTRON advice needed 2Nov 19, 2009 11:23 pm ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: ACTRON advice needed 5Nov 26, 2009 5:20 pm 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Re: ACTRON advice needed 9Dec 04, 2009 1:43 pm 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Re: ACTRON advice needed 12Dec 07, 2009 10:59 am 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Re: ACTRON advice needed 13Dec 07, 2009 7:35 pm ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: ACTRON advice needed 15Dec 08, 2009 7:27 pm mat Hi we have had a quote to install Actron ducted aircon. The model on the quote isSRV175C/E ? I cannot find that model listed anywhere. The specs listed on the quote are, Controller 8 Zones Maximum zone usage 17.7Kw/1100 L/S We are having 5 zones, 9 outlets price $14240 Does anyone know if this is a good model, and is the price reasonable ? ( we do not need to set the temp for each zone) Thanks SRV175E is in their current brochure I know someone with the next size up, the SRV190E and same number of zones as you, paid $12k including GST. Unless you have some very difficult or overriding considerations I'd say $14250 is too much, definitely get more quotes. Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7005 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17905 |
