Window tinting
I have a 1 bed unit in Melbourne with large north facing and south facing windows. I need to reduce the heat in summer. Am having ceiling insulation installed and curtains.
Re solar film
1. Can anyone tell me if having just the north facing windows lined with solar film will benefit me. Finances are a bit tight so don't want to have all the windows done if not absolutely necessary.
Or it is a must to have all done.
2. Is there any particular rating etc that I should be considering when i get quotes?
All suggestions most appreciated.
many thanks
http://www.wers.net/residential/wers-for-window-film
The windows parameter is SHGC - solar heat gain coefficient. The lower the better.
MEP films just talk about total heat energy rejected. The higher the better.
http://www.mepfilms.co.nz/brochures/mep_spec_guide.pdf
So I'd suggest that a small awning on the outside might be a better option - that way if properly designed it could let in the winter wamth and stop the summer heat.
Good summer gain reducing windows films will do the summer bit - but think about both seasons.
1
that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink
