Browse Forums Heating, Cooling & Insulation 1 Oct 24, 2009 9:41 pm Guys, can someone suggest me whats best value for money - a solar powered roof fan or whirlibird . Mine is medium size house and gets hot very quickly as sun comes out..infact sometime its cooler outside than inside ... can suggestions on both products plz ?? Re: Solar Roof Fan or Standard Whirlibird ? 3Oct 25, 2009 9:45 am I would paint your roof white or staple foil under the roof. Re: Solar Roof Fan or Standard Whirlibird ? 7Oct 25, 2009 1:04 pm Okay, no worries, I see you've been discussing insulation elsewhere, and whether whirlybird type products give you any benefits has been debated at length. I just thought no point discussing the finer details of various products if it turns out your roof doesn't even have insulation. Re: Solar Roof Fan or Standard Whirlibird ? 8Oct 25, 2009 2:20 pm Macy Okay, no worries, I see you've been discussing insulation elsewhere, and whether whirlybird type products give you any benefits has been debated at length. I just thought no point discussing the finer details of various products if it turns out your roof doesn't even have insulation. FYI ... roof has insulation but only R2.5 so i was thinking of upgrading that as well if that helps..but i think i need some sort of ventilation as heat really gets trapped inside..any suggestions ? Re: Solar Roof Fan or Standard Whirlibird ? 9Oct 25, 2009 2:54 pm Like I said, the benefit of having those things has been debated at length. I have read in a few places that they really only make a significant difference if you have a raked ceiling and have them drawing hot air out of the top of the room, not the roof space, and I am inclined to agree with that. namz Mine is medium size house and gets hot very quickly as sun comes out..infact sometime its cooler outside than inside ... Have you looked at your window situation... orientation, shading...? Re: Solar Roof Fan or Standard Whirlibird ? 10Oct 26, 2009 10:25 am I would go for a roof fan. Whirlybirds work at the wrong times. A few good products are the solar star (get the 240v product with a thermostat) or look at solar breeze or solar venti. You only want the thing to be venting when it is hot (ie summer) not winter. Re: Solar Roof Fan or Standard Whirlibird ? 11Oct 26, 2009 10:30 am lambchoppa I would go for a roof fan. Whirlybirds work at the wrong times. A few good products are the solar star (get the 240v product with a thermostat) or look at solar breeze or solar venti. You only want the thing to be venting when it is hot (ie summer) not winter. If you are moving air out then take it directly out of the living space through the ceiling and then the roof. Removing it from the roof space itself won't be adequate. I would still use a radiant barrier for the roof to block heat in the first place. Re: Solar Roof Fan or Standard Whirlibird ? 12Oct 26, 2009 10:41 am dymonite69 lambchoppa I would go for a roof fan. Whirlybirds work at the wrong times. A few good products are the solar star (get the 240v product with a thermostat) or look at solar breeze or solar venti. You only want the thing to be venting when it is hot (ie summer) not winter. If you are moving air out then take it directly out of the living space through the ceiling and then the roof. Removing it from the roof space itself won't be adequate. I would still use a radiant barrier for the roof to block heat in the first place. Hey dynomite , can u suggest me some products for radient barrier ? how are they cost wide ? My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5114 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1170 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2550 |
