Browse Forums Heating, Cooling & Insulation 1 Oct 09, 2009 12:11 pm We have about 80 m^2 of tiles in the home being built. we would like to have some under tile heating in some areas, mainly the kitchen, living and dining areas to keep us from freezing in winter. What are my options, and what are the costs involved in doing this? Re: Under Tile heating Costs 2Oct 09, 2009 12:18 pm I would check out the running cost before using this for a large area. A builder we had a chat with said one of the houses he built had underfloor heating throughout, however they only used it until they received their first utility bill. Bit of a shame for the expense of it, and then never be used. Re: Under Tile heating Costs 3Oct 27, 2009 12:26 pm Have a look at speedheat.com.au. Sawe them at a home show & have just received quotes from them. Their under tile heaters are only about 2mm thick. Because they're directly under the tile, not in the slab, they heat up quickly. They are also pretty low wattage. Their site gives some figures on run cost per hour. HTH Re: Under Tile heating Costs 4Dec 10, 2009 11:15 am We had an under-tile floor heating system installed in WA & it cost around $60 per sqm, so if the price is the same in VIC you would probably be looking at about $5k all up including thermostats. Works great - we love ours. We used Radiant Floor Heating - I think they have suppliers in all states. Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16142 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4809 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5842 |
