Browse Forums Heating, Cooling & Insulation 1 Oct 03, 2009 8:25 am A question to all of you that currently use a solar HWS with gas boost - do you ever get fluctuating water temps? This morning my shower was going from a nice warm temp to luke warm It was sunny outside at 7:30am so I'm wondering if the Solar bit was trying to do its thing and then the gas would kick in for a few seconds before switching back again - is this normal?? No other taps were running, but the gas ducted heating was on. I've had a look at the manuals and the SHWS doesn't mention water fluctuations and the Gas boost one says to make sure other taps aren't on, which they weren't. Has anyone else experienced this? If so, is it normal or should I get it looked at? I will keep an eye on it to see how it goes too 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Solar Hot Water System 2Oct 03, 2009 8:28 am Quick question: Do you have a low flow water saving showerhead? and what state are you in again?? ~W~ Building our forever home - Lilium Estate Clyde - Land due May 2019 Built our first home - Pakenham - 2011 Re: Solar Hot Water System 3Oct 03, 2009 8:32 am *frosty* Quick question: Do you have a low flow water saving showerhead? and what state are you in again?? Yes, and Victoria. It's been fine the last few days since I moved in on Wednesday 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Solar Hot Water System 4Oct 03, 2009 8:42 am Its the shower-head then. It's a common problem with continuous flow gas systems, there has to be a certain amount of water pressure coming through the pipes for the Heat element to kick in. Low flow shower heads tend to make the water pressure inconsistent for some reason. You're probably partly right, it was probably sending the water to the collector for heating first, which may explain the extreme difference in the temp, because the water moving around in so many directions is bound to play with the pressure of it running through the system. This is a common problem with some types of continuous flow systems, not just solar, but it does seem to be more obvious with solar. Manufactures are aware of the problem and I know Dux are running though a heap of R & D to fix it. No advice unfortunately, when the whether warms up and you don't need the gas boost, it will be better, but it might be worth trying a couple different types of shower heads. ~W~ Building our forever home - Lilium Estate Clyde - Land due May 2019 Built our first home - Pakenham - 2011 Re: Solar Hot Water System 5Oct 03, 2009 10:04 am We have the same HWS but don't have any issues with temps fluctuating. It takes a bit of fiddling to get the temperature just right to begin with, but that's all to do with plumbing/water pressure. Once you have it how you want it, there's no change unless some so-and-so turns on a tap somewhere else. Which shower head do you have? Re: Solar Hot Water System 6Oct 04, 2009 10:46 am kek We have the same HWS but don't have any issues with temps fluctuating. It takes a bit of fiddling to get the temperature just right to begin with, but that's all to do with plumbing/water pressure. Once you have it how you want it, there's no change unless some so-and-so turns on a tap somewhere else. Which shower head do you have? It's the shower rail one that the builder (PD) supplied, not sure of a brand. The water was fine last night and again this morning - who knows if it will happen again 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12432 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20220 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24140 |
