Insulation for walls?? (to reduce noise)
Wrapping insulation around waste pipes, etc will help dramatically reduce the sounds of toilets flushing.
It's something I did in my current home, and something I am doing in my new one.
Can I put that in my internal walls to help lower the noise (currently have a few walls off at my house after getting asbestos removed)? The only problem would be that the insulation is 75mm and my studs are 70mm however I'd be using it more as a sound insulator than a thermal one.
Ohh that sounds like what I need. Can any kind of insulation be used. We are getting SilverCell in our roof which is the foil looking one. Would we have to use something else?
I'm sure your builder will have various options for this situation.... maybe it is something they will let you do yourselves. I have read on here about people doing their own sound (acoustic?) insulation.
I think the insulation for sound is different stuff from the usual.
Good luck
10
Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This…
29/02/2024
4
Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window…
15/06/2023
Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like…
