Browse Forums Heating, Cooling & Insulation 1 Sep 08, 2009 10:39 am Hi, I was wondering if there was a minimum size of ducting requried for evap cooling seeing that the air is heavier and wet than normal air. In the case of heating ducts you can get away with 6" ducts in the bedrooms (3.2x3.5) and perhaps 8" for the bigger open plan areas. What about evap cooled air though? I spoke to a company (installtion) in Perth and the lady said that the minimum for a master bedroom of 3.6x4.0 would be 350mm (about 13") !! Thats a BIG duct Any ideas, theories ? Suburbia is where the developer bulldozes out the trees, then names the streets after them. My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6920 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5417 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15767 |
