Browse Forums Heating, Cooling & Insulation 1 Sep 06, 2009 7:38 pm We've been obtaining quotes for split systems for our soon to be renovated unit in Sydney and I have the distinct feeling that the solution is being over specified. The outdoor Condenser units I have had quotes for vary considerably in output from 7.5Kw to 11.2Kw cooling. Given the variables described below, what cooling/heating output should we be looking for? The floor area of the conditioned area of unit is approx 85 m2, Ceiling Height is 2.74 m thus volume is around 232 m3. It's on the top (8th floor) of a 1930's concrete framed, brick fronted, block of units - mainly facing East with a tiled pitched roof above - see attached plan. Bats will be installed in the roof during the renovation and windows will be replaced with laminated glass units. We can't use the roof space for a ducted system (due to the Body Corporate -Grrrr) so we have reverted to a 4-head spilt system (outlets: bedroom, living room, dining, kitchen) with the Condenser at the far end of the rear terrace. Plan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Click for bigger More photos & plans at http://www.tinyurl.com/85macleay Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8994 Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 20174 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15770 |
