Browse Forums Heating, Cooling & Insulation 1 Aug 24, 2009 1:02 pm Our builder does not cover the cost of AC ,we're currently based in Darwin Nt and planning to move to Perth when our house is complete.We are not sure which Ac and heating would work well for Perth. We wish to have a ducted system .Is it possible to have our heating done by gas with heat still going through those same ducts as that the Ac ? Re: Seeking info on heating & cooling options for new hse Perth 2Aug 24, 2009 1:09 pm Hi. I'm not from Perth but in answer to your question...yes, you can have the heating and cooling through the same ducts (the larger ductwork is required). We are looking into ours at the moment - gas ducted heating with add-on refrigerated air conditioning. Tossing up between Brivis and Lennox. Re: Seeking info on heating & cooling options for new hse Perth 3Aug 24, 2009 4:34 pm Trinity Hi. I'm not from Perth but in answer to your question...yes, you can have the heating and cooling through the same ducts (the larger ductwork is required). We are looking into ours at the moment - gas ducted heating with add-on refrigerated air conditioning. Tossing up between Brivis and Lennox. How much is that all going to cost you? Re: Seeking info on heating & cooling options for new hse Perth 4Aug 24, 2009 5:31 pm am awaiting the quotes - hopefully will receive them in the next few days. I'm expecting around the $12K mark - home will be about 250sq meters, 12 ducts, 9ft ceilings, multiple zones. Re: Seeking info on heating & cooling options for new hse Perth 5Aug 25, 2009 1:08 am types of heating in Perth? well gas is the most common. reverse cycle ducted as well. cooling as above, or evap a/c is very very common all over Perth. Re: Seeking info on heating & cooling options for new hse Perth 6Aug 25, 2009 8:31 am depending on where in perth you are building evap might not be the best solution for cooling. We had evap when we lived in Perth and we were happy with it but we lived reasonably close to the coast and our house was orientated on the block to get the best cooling sea breezes. many others in perth dislike evap. We also had soem ceiling fans to assist when it was very humid. We had natural gas heating for winter. This time we are no longer in Perth, rather in the country and we have refrigerative reverse cycle aircon. Ours is a fully electric system. You need to consider the following -availability of natural gas as opposed to bottled. Does where you are building have it? e.g. Yanchep is on bottled gas and so are some parts of suburban Perth. ( bottled is expensive so heating a house this way is very pricey) - are you having gas in the house for anything else? - house orientation -plan of house ( for example because of the size of our main open plan living area heating with gas would have been impractical- too expensive and would have required the biggest heater on the market and then not done the best job anyway.Just re-read your post and noticed you want a ducted system anyway...... - location of house are you close to the coast or inland. Where we are now is inland by 35 kms or so and it gets quite humid so evap wasn't a wise choice for cooling. Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6688 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5124 |
