Browse Forums Heating, Cooling & Insulation 1 Aug 23, 2009 3:57 pm I'm looking to install a new gas hot water system to replace my existing electric hot water service. Does anyone know if I'm eligible (nsw) for a govt.rebate on a continuous flow gas hot water system and not a combined solar/gas system? camelia I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14059 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
