Browse Forums Heating, Cooling & Insulation 1 Aug 13, 2009 10:04 pm We are building a split level house. One level is on a concrete slab, and the dual storey has a wooden floor between the 2 levels. I want to insulate the ceiling from underneath so that the wooden floor doesnt make alot of noise when walked on. any one got any suggestions??? Re: under wooden floor insulation suggestions - dual story house 2Aug 13, 2009 11:09 pm chatterbox We are building a split level house. One level is on a concrete slab, and the dual storey has a wooden floor between the 2 levels. I want to insulate the ceiling from underneath so that the wooden floor doesnt make alot of noise when walked on. any one got any suggestions??? This might something that may help you. You don't have to use their product but the principles is the same. Noise travels travels along the joists as much as through the floor. You need to address this interface. http://www.acoustica.com.au/acoustiflex.html They make a recycled mass loaded vinyl which is a highly dense rubbery material that deadens sound. Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9100 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8369 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4041 |
