Browse Forums Heating, Cooling & Insulation 1 May 30, 2007 11:25 am Hi everyone,
Came across these guys: http://www.ecosmartfire.com/home.php A flu-less and enviro friendly fireplace - apparently runs on ethanol. But where the heck do you purchase ethanol from? Edit - d'oh! it runs on dentured ethanol - which is apparently methylated spirits! Re: Fireplace - ethanol based 2May 30, 2007 11:31 am Does the ethanol mean it goes faster than other fires??
![]() ![]() ![]() Re: Fireplace - ethanol based 3May 30, 2007 11:34 am I think prices start at $2900 - and no flue needed - so no ghastly installation costs!
Our builder is charging $8k ![]() Re: Fireplace - ethanol based 4May 30, 2007 12:21 pm Hmm
A metho fireplace. Is that going backwards or forwards? http://www.ecosmartfire.com/about_fuel.php From my knowledge and expereince when camping with a meths stove it is not the hottest of heating fuels - you can put meths on your hand and burn it without being burnt and you need to be at the very top of the flame to get the hottest temperature. They say you don't need to flue, OK, so what is the heat output (BTU) into the room per unit of fuel, versus the cost to buy the fuel per unit etc etc before I would jump one way of the other. Interesting product, lots of german text on their site, so maybe they are importing a trend from Europe. I like the idea of a reuseable fuel and it all needs to be weighed up. Steve Re: Fireplace - ethanol based 5May 30, 2007 12:25 pm What about one of these stonecutter.Just kidding really.We still do them now and then in this area (pretty cold)but people are starting to put them outside under their pergolas etc rather than inside.We've done a few over the last couple of seasons in a winery,a pub,and another under my own pergola.I noticed that wood burning ovens for cooking pizza,bread,etc,are becoming popular in some areas although I haven't built one of those yet.Regards Terry.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Fireplace - ethanol based 6May 30, 2007 12:38 pm The other thing that comes to mind re the metho fire, is open flames are VERY dangerous for kids and loose clothing. I'm very sruprised that they are allowed to have the open flame in such a device.
re the wood fire - Yep they work terry, but I prefer a combustion wood fire that stay alight and uses less fuel per hour - ![]() ![]() Steve Re: Fireplace - ethanol based 7May 30, 2007 12:43 pm Terry - love the idea of the outdoor wood fire place!
Yak Chat - I found this on the site about output: Thermal Input: 14 Mj/hr – 13,000 BTU – 3.5 Kw/hr Thermal Efficiency: Over 90% Heats on Average: Over 35 m2 OR 376.74 ft2 Fuel Consumption: 0.64 Ltr/hr OR 0.17 Gal/hr on MAX 0.49 Ltr/hr OR 0.13 Gal/hr on MED 0.28 Ltr/hr OR 0.074 Gal/hr on MIN In general 5 Litres OR 1¼ Gal of fuel would last from 7 hours on MAX and up to 20 hours on MIN setting. http://www.ecosmartfire.com/fuel_efficiency.php Re: Fireplace - ethanol based 8May 30, 2007 1:43 pm I agree Steve.I think open fireplaces belong in old country pubs and outside pergola areas where they provide a great focal point.We light ours when we have people here for tea on a winters night and they just love sitting around it.If you build them right you can get quite abit of heat out of them despite what they say.Regards Terry Re: Fireplace - ethanol based 9May 30, 2007 2:50 pm SC
I think you will find an interesting bit of info at the link below re metho's performance. Around half that of gas. As per my original point - Metho is not a HOT fuel, and weight for weight, bang for buck it might not be that good a choice. I think there are also issues of how much fuel you have to store at home to use it. Does your insurance policy cover holding 100 litre (let's say 20 days supply) of metho beside your house. Make sure it does!!! Also metho evaporates pretty quickly, so really it would be better in 20 litre drums, then you have to decant etc to use it. I have had oil heaters in one house and this is basically a low grade heating kero with a 100litre tank and that got very expensive to run due to the cost of oil based products. I think this thing is more a looks nice, etc, but just a flame in the air is not that efficient - it should be heating a solid surface - ie like the gas log fires which heat up a solid mass for extra heat release. Have you looked at gas space heating, and maybe some extra insulation to lower your heating needs. As I've said before, I lived in a swedish house in 10 degree weather with no heating on and 3 people's body heat kept the house at around 22 inside. http://www.bushwalking.org.au/FAQ/FAQ_Efficiency.htm#Usage Hope this helps. Steve Re: Fireplace - ethanol based 10May 30, 2007 2:55 pm We'd be having a fireplace purely for the "ambience" factor as the house will have ducted reverse cycle AC, plus passive solar design and insulation (R3 in the ceiling, R1.5 in the walls).
I don't think we'll turn on the ducted heating in the bedrooms - more likely use something like Econoheat: http://www.econoheatsa.com.au/ (We don't really want to have A/C - but it's better to have it installed for re-sale value of the home) Re: Fireplace - ethanol based 11May 30, 2007 3:23 pm Cool.... Or is that WARM... ![]() If it's not as primary heatting then it could be ideal for ambience. Or you could buy one of those silk fire things with air flicking it up for ambience (NOT) ![]() ![]() On the other front, how much $ do you think the aircon helps with resale, I say zip to me but that's because I see it as a no value thing for me. Steve Re: Fireplace - ethanol based 12May 30, 2007 3:40 pm Sydney siders are in love with their air-con units. Not sure what Adelaide summers are like, but Sydney's are hot and humid - it's more the humidity that people are likely to use the air con for.
I'd also say it's because most project builders that do big box mansions that aren't designed for passive heating & cooling need it! Re: Fireplace - ethanol based 13Nov 19, 2010 10:33 pm Check the ethanol fireplace from the Planika Fires Re: Fireplace - ethanol based 14Nov 22, 2010 11:37 pm I think for looks they're a great alternative to an 8k (plus surrounds) built in- then again the 8k one we're looking at having doesn't have enough heat output for out open living area either. If you actually want to use it to heat, then you're wasting money. If you are running your heating AND the good looking heater at the same time, that's just plain bad for the planet. Painters: what would you do? I’m painting water based over oil based trims, & the first coat of undercoat / primer has failed the scratch test. I sanded with 120 grit… 0 1221 I don’t know how to edit… It’s not brushwood, I meant to write brushbox 1 3618 Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 740 |
