Browse Forums Heating, Cooling & Insulation 1 Aug 08, 2009 10:39 am Hi With this new government policy of free insulation, i have had heaps of people ask me if i want my roof insulated. I am not too sure if the insulation really works in summer. Any advice David Re: Insulation 3Aug 08, 2009 7:20 pm It can help reduce the inside temperature by up to 10"c in summer and up to 10'c warmer in winter, especially if you use good blockout curtains or blinds aswell. No house should be without insulation IMO Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: Insulation 4Aug 09, 2009 12:15 am Hels It can help reduce the inside temperature by up to 10"c in summer and up to 10'c warmer in winter, especially if you use good blockout curtains or blinds aswell. No house should be without insulation IMO It will depend on the thickness of the batt. In this study you can infer these temperature reductions based on a 35 degree C day. 2.8 deg C - for a 3 inch (75mm) batt - R 1.5 5 deg C - for a 6 inch (150mm) batt - R 3.5 http://www.fsec.ucf.edu/en/publications ... N-6-86.pdf You can get batts that go up to R 6.0 (250mm) or 10 inches thick. On a 35 degree day the roof space temperature under a typical non-reflective roof can climb to 87 degrees. This is virtually eliminated by having an additional piece of foil sisalation underneath it. Re: Insulation 6Aug 17, 2009 4:47 pm bulldoggie In sydney metro. Do i need to ventilate my roof too? It has been shown that if your roof space is separate from your living space then ventilating it does little to change the temperature in the house. Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11277 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6207 |
