Browse Forums Heating, Cooling & Insulation 1 Aug 08, 2009 6:54 am 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Coverage on Ceiling Fans 8Aug 09, 2009 10:51 am 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Coverage on Ceiling Fans 10Aug 10, 2009 8:11 pm I've never found metal blades noisy except on flat out, and they never used to get turned off for almost all the year. They helped stop the mould gorwingin the ceilings. And article re scientific measurement and fan tip being the limit. http://www.fsec.ucf.edu/en/publications/pdf/FSEC-CR-1770-98.pdf and I'd recommend the offset placement as being best to create a cyclic effect of air movement through the room. Mind you - Directly mounted above the bed on a stinking hot night and the fan on flat out is always effective. It looks like Blacktown council allows up to a 6.0m wide driveway so just ask your builder to change the plans. If you are just in the planning stage then there is no… 6 3871 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10614 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5897 |
