Browse Forums Heating, Cooling & Insulation Re: Sarking on a tiled roof? 3Jul 30, 2009 11:15 pm ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Sarking on a tiled roof? 4Jul 30, 2009 11:19 pm nietzche i get sarking with a colorbond roof, does it work the same for a tiled roof? is it necessary or a nice to have? thanks! Foil sarking will keep the house cooler in summer and act as moisture barrier. It's also a requirement for bushfire prone areas. We have it under our Zincalume roof. Re: Sarking on a tiled roof? 8Sep 02, 2009 4:38 pm Yup, we have flat profile roof tiles and we were asked to put in sarking by the basix assessment. Luckily our builder threw that in for FREE! --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: Sarking on a tiled roof? 12Sep 12, 2009 12:28 am Some builders I talked to said that sarking is not necessary and not required by council. Sarking will actually make the roof hotter because the hot temperature is trapped between the sarking and roof insulation. Is this true? Waiting for 2010 Land registration.... Re: Sarking on a tiled roof? 13Sep 12, 2009 9:15 am aya99 Some builders I talked to said that sarking is not necessary and not required by council. Sarking will actually make the roof hotter because the hot temperature is trapped between the sarking and roof insulation. Is this true? Maybe so but does that matter? It's role is to keep your ceiling cool (or the batts above it cool) so that all that heat doesn't radiate into your house. Sarking is very easy to roll down before the roof goes on. Much harder afterwards - most roofers won't try so it becomes DIY. Re: Sarking on a tiled roof? 14Sep 12, 2009 9:16 am cyberman jcjuice can sarking be installed AFTER the roof has been put on/finished? Not without removing all the tiles. You could hang it below the battens but it is fiddly. Re: Sarking on a tiled roof? 15Sep 13, 2009 1:01 am Do you think it will add value to the house? Is it going to be noisy (the flaps) ? dymonite69 aya99 Some builders I talked to said that sarking is not necessary and not required by council. Sarking will actually make the roof hotter because the hot temperature is trapped between the sarking and roof insulation. Is this true? Maybe so but does that matter? It's role is to keep your ceiling cool (or the batts above it cool) so that all that heat doesn't radiate into your house. Sarking is very easy to roll down before the roof goes on. Much harder afterwards - most roofers won't try so it becomes DIY. Waiting for 2010 Land registration.... Re: Sarking on a tiled roof? 16Sep 13, 2009 10:21 am aya99 Do you think it will add value to the house? No. I doubt anyone is going to ask whether a house has sarking when they go to buy a "second-hand" house. On the other hand, my present house has a colorbond roof without sarking. It is incredibly hot in the roof space. So much that during summer the cold water taps are noticeably hotter than the "hot" water (until a considerable amount of water has been used to clear out the water that's been sitting in the pipes in the roof space). Re: Sarking on a tiled roof? 17Sep 13, 2009 8:07 pm aya99 Do you think it will add value to the house? I won't speculate on how the market views this in the future. The roof space temperature can be reduced by around 40 degrees. It can make your house more comfortable in summer and reduce air con running costs by up to 20%. As electricity costs rise then this may mean something to a prospective buyer. BTW the cost of sarking is around $5/m2 which is fairly trivial contribution to the total cost of a house that starts at $800/m2. Re: Sarking on a tiled roof? 18Sep 13, 2009 10:11 pm Thanks, dymonite69. I think you're right. I'll include that in my building contract then. dymonite69 aya99 Do you think it will add value to the house? I won't speculate on how the market views this in the future. The roof space temperature can be reduced by around 40 degrees. It can make your house more comfortable in summer and reduce air con running costs by up to 20%. As electricity costs rise then this may mean something to a prospective buyer. BTW the cost of sarking is around $5/m2 which is fairly trivial contribution to the total cost of a house that starts at $800/m2. Waiting for 2010 Land registration.... Re: Sarking on a tiled roof? 19Sep 13, 2009 10:15 pm Really, that hot? Why would you go to the roof space? Yeah, I know what you mean, the cold water in my house is so hot too when it's summer. Anyway, I'll include sarking to the new house then. cyberman aya99 Do you think it will add value to the house? No. I doubt anyone is going to ask whether a house has sarking when they go to buy a "second-hand" house. On the other hand, my present house has a colorbond roof without sarking. It is incredibly hot in the roof space. So much that during summer the cold water taps are noticeably hotter than the "hot" water (until a considerable amount of water has been used to clear out the water that's been sitting in the pipes in the roof space). Waiting for 2010 Land registration.... Building Standards; Getting It Right! Hi all I’m in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 11726 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4938 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2543 |
