Browse Forums Heating, Cooling & Insulation Re: continuous flow hot water system 2Jun 17, 2009 5:09 pm IMHO.........Instantaneous (Continuous) Gas Hot Water Systems are not the best option for the typical McMansion. They are 'big' in Japan because they are small in size. And space is a premium there. Rinnai have marketed Instantaneous systems in Australia wonderfully.... even making them 'sexy' with temperature touch controllers. They have made HWS a high involvement purchase where HWS was once very low involvement. In response, Rheem (a Japenese owned company) introduced their versions and others too jave followed. However, these systems have big draw backs. They are OK for small homes (great for flats) where space is tight. They are relatively expensive. They don't cope well with high water demands (they will limit the water flow in order to heat the extra volume). There are better systems for local conditions. A mains pressure gas storage hot water system is much better (lower purchase cost too) and a solar bosted gas storage hot water system is even better. With RECS and rebates.... not that costly. I would not install an Instantaneous Gas HWS in my house. Had the builder included it, I would have even paid to have it changed. However, having said all that..... the decision on what HWS to select is not always a rational one. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14026 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6983 You may still have a case, but your next step is to speak to a lawyer. 3 1624 |
