Browse Forums Heating, Cooling & Insulation 1 May 01, 2009 6:57 pm Hi guys We're getting 78mm thick wall frames. When enquired about insulation limitations on the thickness of the wall frames I was told that they normally use Insualbreak 65 as insulation on external walls. Now, I've just been sent a sample and it's only 5mm thick. Will this be sufficient? :S Somehow I think not... Is anyone familiar with steel frame wall thickness and its impact on insulation? By the way, most of the other steel frame quotes were based on 92mm thick wall frames. Re: steel wall frame thickness and insulation 2May 01, 2009 7:02 pm Not familiar with SA rules but your product is poor if it's used on its own... http://www.air-cell.com.au/pdf/brochure ... .flyer.pdf "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: steel wall frame thickness and insulation 3May 01, 2009 7:06 pm ed @ EcoClassic Not familiar with SA rules but your product is poor if it's used on its own... http://www.air-cell.com.au/pdf/brochure ... .flyer.pdf That's what I thought When I asked the steel frame supplier what the insulation limitations of going with this thickness of steel frame were he avoided my question. Does anyone knwo what the maximum thickness of insulation can fit with 78mm thick steel frames? Re: steel wall frame thickness and insulation 4May 01, 2009 7:13 pm I'm building with W&M (supal0c). Sections are c-shaped, 75mm x 32mm, steel itself about 0.5mm thick. R2 rockwool sound screen acoustic batt external wall insulation came standard. For ceiling, I upgraded to R3. R0.2??? What the .... Chris Re: steel wall frame thickness and insulation 5May 01, 2009 8:37 pm ChrisL I'm building with W&M (supal0c). Sections are c-shaped, 75mm x 32mm, steel itself about 0.5mm thick. R2 rockwool sound screen acoustic batt external wall insulation came standard. For ceiling, I upgraded to R3. R0.2??? What the .... Chris So do you think I should be fine with fitting R3 and R2 "inside" 78mm frames? :S Re: steel wall frame thickness and insulation 6May 01, 2009 8:46 pm All insulation batts seem to come with the recommendation against squashing. If you wanted to stick to the spec, the thickest batts you could fit would be 78mm. I've seen the polysterene boards avertised somewhere, 75mm thick, with R value of 2 (I think), which would much more effective. There're also 78mm thick rock wool batts, but both poly boards and these batts are rather expensive. So it all depends on how much you want to spend. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: steel wall frame thickness and insulation 7May 01, 2009 8:49 pm W&M only do Supal0c and have R2 as standard (external wall, including wall between house and garage). So, cannot imagine why you cannot at least fit R2 in your case. Can't be 100% sure about R3 coz my R3 batts are for the ceiling. Chris Re: steel wall frame thickness and insulation 8May 01, 2009 9:11 pm ChrisL W&M only do Supal0c and have R2 as standard (external wall, including wall between house and garage). So, cannot imagine why you cannot at least fit R2 in your case. Can't be 100% sure about R3 coz my R3 batts are for the ceiling. Chris Our architect has recommended R1.5 for the external walls and R3 for the ceiling. Hope it will be ok Does R2 provide 25% more insulation than R1.5? Re: steel wall frame thickness and insulation 9May 01, 2009 9:13 pm Being a two storey house do you think we should go R2 upstairs but stick with R1.5 downstairs? Would it make much difference? Re: steel wall frame thickness and insulation 10May 01, 2009 9:24 pm gettingThere Does R2 provide 25% more insulation than R1.5? gettingThere do you think we should go R2 upstairs but stick with R1.5 downstairs? Would it make much difference? Errr, pass. I didn't apply any science in my decision. One of the other builders I went out to quote has R3 in the ceiling as standard. When I decided on W&M, I figured that insulation upgrade was money well spent (probably save many times that in years to come). Chris Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14435 This is 100% true. You can not hang anything on steel frames. very frustrating 8 5345 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4441 |
