Browse Forums Heating, Cooling & Insulation 1 Mar 24, 2009 10:52 am Can someone advise me please. I have a split system due to be installed on my lounge wall which backs onto my carport. A few installers have advised that I can mount the outside part on the carport roof. I am sure I have read somewhere not to do that as it will be exposed to the full sun and elements? Is this correct?? Re: Installation on carport roof? 2Mar 24, 2009 1:39 pm thats just ******* it will look sh1t if it is installed on top of your carport roof! try to put it down the side of the house instead. maybe they were trying to cut corners by saving on pipes etc.? cheers, KM Melington - what a cool concept! Re: Installation on carport roof? 3Mar 24, 2009 2:46 pm My sister has hers on her carport roof and it works fine, although does look a bit weird 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Installation on carport roof? 4Mar 24, 2009 4:43 pm Also check your estate guidelines.. Ours has strict guidelines on air con units being visable from the street etc. If its at ground level that wont be an issue. -------------------------------------------------------- Building in Highlands Craigieburn Status: Building the Laundryless 25.5: Slab Complete Re: Installation on carport roof? 5Mar 24, 2009 7:07 pm I agree with others, it may look a little strange and may not be in council requirements. The unit however is fine out in the elements as this is what they are designed for. The unit will get good airflow which will help it run effectively. Re: Installation on carport roof? 6Mar 24, 2009 10:24 pm had ours installed in a good spot for years and then next door decided to extend their back room - cut off all the air flow for it and it was shagged 3 weeks into summer! good airflow is a must even if it has to go on top of the carport 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Installation on carport roof? 7Mar 25, 2009 10:24 am Thanks guys. Re: cost saving on the pipes etc, can't see that it would be much difference as it is basically a back to back installation its just that my carport is a little narrow so I think they thought rather than clog up the carport, stick it on the carport roof. Re: council etc, 2 other units in my block have theirs on the carport roof (probably where the installer got the idea from too) It would be equally visible if it were on the ground as opposed to on the roof. I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5166 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6085 |
