Browse Forums Heating, Cooling & Insulation 1 Mar 16, 2009 9:27 am I need a slim line gas log fire so I can hang my tele at a reasonable height. I have found none that flue straight to the external wall.
The other option is a double sided for an internal wall that can flue through the 1st floor to outside, not through the roof cavity. Escea 850 =$6000 is the only one I can find. Re: Slim gas log fire 2Mar 16, 2009 2:18 pm Have you looked at the Heat n Glo range? We are having one of these put in with the new build. It will be vented directly out the external wall therefore not requiring flueing through the roof space. The 550TRsi model we are getting is only 415mm deep also. Fully installed from the builder with a 20mm Quantum Quartz hearth is $8400. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Slim gas log fire 3May 13, 2009 12:05 pm try abbey fireplaces website they have a lot of different types info and costs on their site You have to go and check out the ones you like in person as some have a poor flame effect Mike 2/3 of the way thru the build Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10815 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 15118 We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5250 |
