air con options - flat roof
We could look at boxing ductwork in, but that would be within the room space.
As far as I can see our only option involves splits or multisplits.
Our builder has installer lg art cool system in his house and recommends this. Does anyone have any experience with these?
What are other options available to me.
Thanks
K
1) To drop a ceiling in laundry or over kitchen or both. Usually need at least 500mm of dropped ceiling to be able to accommodate an air conditioning unit. Bare in mind you probably dont want your return air grille in the kitchen so you would need to drop a hallway or something else as well. Basically need dropped ceilings anywhere you want to get ducting too. You also need at least 3 or 4 courses dropped to be able to run ducting. If you cannot (or do not) want to add any dropped ceilings...
How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity?
11/11/2023
Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room…
11/11/2023
Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),…
