Browse Forums Heating, Cooling & Insulation 1 May 05, 2007 1:28 pm From 1st May 2007 it is mandatory that all WA homes must now be 5-star energy rated. I am about to build a steel frame home on stumps and a 5-star report is required. Was wondering if anyone had any ideas about the best way to insulate this type of home and with what product. I am aware of an air-cell product that can be used in the walls and floors but was wondering if other options are out there - pole homes are difficult to 5-star rate due to the energy escaping/entering through the flooring system. Re: New 5-star energy rating BCA codes 2May 05, 2007 3:51 pm Bats could be the way to go.But difficult to advise from Victoria as I don't know if WA will be using a similar software program for determining the 5 star pass.Here we have a mix n match cut n paste type vehicle which allows all sorts of different outcomes including window size,R rating of bats in walls,ceilings and under floor,double glazing to some windows etc.Finally we must have either a water tank duel plumbed to the toilets or a solar panel duel hotwater service.
In the end two operators could enter the same initial data for a house and come up with two different reports...Weird science imho. 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 1567 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110781 |
