Browse Forums Heating, Cooling & Insulation 1 Feb 08, 2009 1:44 pm I need to put an aircon in my new house.
The problem is there is NO appropriate wall space for where I want to put it to give the maximum use. This is the most sensible wall to use and as you can see, there is not enough room to put one on. I know I will have to have a chat to my installer, but does anyone know if you can mount them vertically on a wall? It will need to go where the clock is currently. The clock is NOT mine by the way, current owner’s photos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wall Aircon units …. 2Feb 08, 2009 6:21 pm Michelle I need to put an aircon in my new house. The problem is there is NO appropriate wall space for where I want to put it to give the maximum use. Nowadays they can mount them on the floor, ceiling or bulkhead. http://www.mitsubishielectric.com.au/re ... ioning.htm Re: Wall Aircon units …. 3Feb 08, 2009 6:26 pm Ha! We have a clock like that that was given to us by a family member!! Maybe we can forget to pack it when we move into our new house, it doesn't work anyway.
I don't know anything about mounting air-con units!! Kate Re: Wall Aircon units …. 4Feb 09, 2009 4:02 pm dymonite69 Michelle I need to put an aircon in my new house. The problem is there is NO appropriate wall space for where I want to put it to give the maximum use. Nowadays they can mount them on the floor, ceiling or bulkhead. http://www.mitsubishielectric.com.au/re ... ioning.htm Thanks for that dymonite69….I guess I will need to get the guy in to give me advice for the best unit. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wall Aircon units …. 5Feb 09, 2009 5:04 pm Another option is a ceiling casette, although they are quite expensive but very effective. You can also have a split system fitted on an internal wall as it works with a pump.
I would get a professional out to have a look and give some quotes. Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: Wall Aircon units …. 6Feb 09, 2009 5:10 pm Hels_n_Greg Another option is a ceiling casette, although they are quite expensive but very effective. You can also have a split system fitted on an internal wall as it works with a pump. I would get a professional out to have a look and give some quotes. Yes…I think that’s the way to go, thanks heaps. I was just wondering if the wall units can go vertical, I’ve never seen them done that way before. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wall Aircon units …. 7Feb 13, 2009 8:13 pm Michelle Hels_n_Greg Another option is a ceiling casette, although they are quite expensive but very effective. You can also have a split system fitted on an internal wall as it works with a pump. I would get a professional out to have a look and give some quotes. Yes…I think that’s the way to go, thanks heaps. I was just wondering if the wall units can go vertical, I’ve never seen them done that way before. I haven't heard of them mounting a standard wall unit vertically. However, there may be a specific unit available that is designed to be hung that way Let me know if you find one as I would interested for our next house. Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: Wall Aircon units …. 8Feb 13, 2009 8:16 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wall Aircon units …. 9Feb 13, 2009 9:02 pm What about one of the LG Art Cool systems? It looks like it will fit into that space.
http://au.lge.com/products/model/detail/residentialac_artcool__a12aw2.jhtml [sneakersss] Re: Wall Aircon units …. 11Feb 15, 2009 10:27 am Very nice, I didn’t know about those.
BUT….did I forget to say I am on a tight budget??? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Wall Aircon units …. 12Feb 15, 2009 10:38 am I don't think they cost much more than a standard wall split.
The other option is box units.
The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15791 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13787 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5189 |
