Browse Forums Heating, Cooling & Insulation Re: paving/concrete slab terrace on north side of house - heat? 2Feb 01, 2009 9:43 am The answer is yes! It'll reflect sun radiation during the day, right into your windows and walls, heating them up, and store the large amount of heat that will be released in the night. All in all, you may expect a significant rise in the ambient summer temperatures around your house.
Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 20187 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5760 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12344 |
