Browse Forums Heating, Cooling & Insulation 1 Jan 30, 2009 9:25 am Hi Guys, I have a Brivis evap cooling unit in my 36 sq house. All my rooms get a good supply of cool air from the unit except my master bedroom and study... its just that the airflow is very minimal compared to the other rooms... can something be done about this? as i need more flow in my bedroom.... Re: Evap Cooling 2Jan 30, 2009 11:58 am PointCookFella Hi Guys, I have a Brivis evap cooling unit in my 36 sq house. All my rooms get a good supply of cool air from the unit except my master bedroom and study... its just that the airflow is very minimal compared to the other rooms... can something be done about this? as i need more flow in my bedroom.... Air, like water flows down the path of least resistance. Resistance can be in the supply air or the outflow. Is the bedroom duct run blocked or too long (do you need a balancing register to reduce reduce flow to other rooms)? Is the relative size of the window opening in the bedroom smaller than for the other rooms? (decrease the openings in other rooms and keep the bedroom window wide open) Is the air flow from other rooms impeded from going through the bedroom? (keep the bedroom door open, open all its windows and decrease the opening in other rooms) Re: Evap Cooling 3Jun 16, 2009 9:40 pm Check your ducts as well. Like PointCookFella said, air runs to the point of least resistance. If the duct is too long or looks like a snake (bends left and right) the airflow maybe somewhat restricted. You may need to also upsize the ducting if none of these things work. A master bedroom is usually a 350mm diameter duct. Maybe you could upsize to a 400mm duct to get more air. |
