Browse Forums Heating, Cooling & Insulation 1 Jan 14, 2009 10:53 pm Just curious if ceiling fans can run off the power supply of existing light fittings or if more wiring was required ?.
A good few years ago we looked at installing fans in my parents house but it turned out that the metal roof would have needed to be pulled back for access. Due to the pool solar heating covering nearly half the roof fans were deemed too hard and we left it. I was wondering if anything had changed perhaps?. Building Upside down house in Wantirna VIC Current Stage: Procrastination... it's just all too hard.... Blog: http://thereluctantbuilder.blogspot.com/ Re: Ceiling Fans Power Supply 2Jan 14, 2009 11:36 pm hi, yes they can, only a small amount of wiring is needed from the fan to the switch and that is all the rest uses the supply from the existing light. as for access it should be easy if you have a good ceiling space with a manhole to get through...im not sure why ur parents had to take of tin from the roof... Re: Ceiling Fans Power Supply 3Jan 14, 2009 11:38 pm Mr Smith hi, yes they can, only a small amount of wiring is needed from the fan to the switch and that is all the rest uses the supply from the existing light. as for access it should be easy if you have a good ceiling space with a manhole to get through...im not sure why ur parents had to take of tin from the roof... Most likely a flat roof. There is plaster inside, then the roof beams then the tin roof... All this equates to no crawl space ... it is all sealed up. It is fairly common in older homes here in Victoria. Re: Ceiling Fans Power Supply 4Jan 14, 2009 11:39 pm Ahh - tin had to be removed because there is no roof cavity at all, its just plaster, insulation and then roof. Building Upside down house in Wantirna VIC Current Stage: Procrastination... it's just all too hard.... Blog: http://thereluctantbuilder.blogspot.com/ Re: Ceiling Fans Power Supply 6Jan 14, 2009 11:49 pm Yup what Matt said
BTW: Matt Congrats, you just turned over 3000 posts ! Just think of all the people you've helped out with all those posts Building Upside down house in Wantirna VIC Current Stage: Procrastination... it's just all too hard.... Blog: http://thereluctantbuilder.blogspot.com/ Re: Ceiling Fans Power Supply 8Jan 20, 2009 5:31 pm So does the light switch need to be 'On' for the fan to work? That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8640 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14231 2 15465 |
