Browse Forums Heating, Cooling & Insulation 1 Dec 19, 2008 4:52 pm We've recently moved into a top (8th) floor apartment in a 1930's building in Sydney where we have access to the attic above.
We want to install reverse-cycle ducted aircon with the heat pump either installed in the attic (it is well vented) or on a back balcony. We also have original decorative plasterwork on some of the ceilings in the rooms which we want to preserve and so we're looking for mini-duct systems to minimise the visual impact of the vents - but I can't seem to find anyone who does them in the Sydney area - any suggestions? Re: Mini-Duct Reverse Cycle Aircon system in Sydney 2Dec 19, 2008 4:57 pm Welcome Pewit - I can't suggest anyone - but make sure you get permission from body corporate before going into the ceiling.
Ceilings are fire rated & protected in apartment blocks. Cutting into the ceiling requires that the contractor do particular work around any points made in the ceiling to retain fire retardancy. Do unauthorised ceiling works and if the contractor doesn't do the appropriate fire steps - and if there is a fire (god forbid) - the insurance taken out by the body corporate for the building won't pay. The body corporate will then hit up the person who conducted the works for damages (who will then in turn sue the owner of the strata unit) I hate to be doom and gloom - but I've seen it happen and it gets ugly After 4 years - we're in! Re: Mini-Duct Reverse Cycle Aircon system in Sydney 3Dec 20, 2008 10:28 pm Whoever did the fire regs on this building failed to notice the piles of wood and asbestos sheet left in the attic!
We're aware that we need to get the body corporate permission and we have to do so for the DA required for removing internal walls - but we also want to put forward a proposal that minimises the impact of our aircon installation to the unit as par of the DA. Despite assurances to contrary before we moved in, we've had water coming through the ceiling during the rainstorm last week - so I went up into the attic and took photos of all the torn sarking and damp timbers - then sent them to the body corporate - now they plan to fix the roof! We hope that this will give us some leverage and also other units already have aircon systems - also the roof repairs will probably make installation easier while they're being fixed. Also as we're on the top floor, there's little impact on anyone else if we put the heat pump on our side of the building. DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 2110 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15800 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13792 |
