Browse Forums Heating, Cooling & Insulation 1 Dec 18, 2008 11:12 am My wife and I just moved to our new house and we plan to install the gas ducted heating system because we really liked that in our last place.
Pls allow me to post three newbie questions here: 1. It is a three-bedroom house with moderate insulation. I need about 6 outputs. Not sure about zones since it is already cheap to use natural gas. How much would it roughly cost in total ( including the (hardware+installation service)? 2. Any recommendation on the brand? I saw Brivis and Breezeair in some other posts, but not sure whether it is related. 3. I live in the Melbourne outer east. Do you have any good contact/tradesman to recommend? Thanks in advance. Re: Advice on gas ducted heating 3Dec 18, 2008 11:52 am Only 10 squares internal. The ceiling is about 2.4-2.5m.
We would love to add referig cooling some time later. But now we have a very tight budget since we just bought our first home.... The outlets I estimated was by no means accurate. I guess the easiest way is to upload my floor plan here. [/img] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice on gas ducted heating 4Dec 18, 2008 12:06 pm Just a a quick look. If you want to add refreidgerated cooling through the same system (ie same ducts) the smallest heater you would need to go for a 2PW20 heater, this gives you the option of adding add on cooling
Which is (20kwatts). However this would be more than you would need for your house. I would proably consider the Wombat 2PW15 which is 15KW. But according to the table i have you cant adding cooling to this model . Also i think you should put one outlet in each of the bedrooms and bathroom. And at least three in the kitchen near the external walls. I dont think you need zoning because there is a minimum number of ducts you need to remain open all the time. But if the experts say you- seperating bedrooms and kitchen this will reduce your running bill further. Regarding price i would say around $3000-3500. depending on model. And if you do intend of running refridgerated a/c later, make sure they install R1 ducting or better. this is the min requirement for a/c cooling. Re: Advice on gas ducted heating 5Dec 18, 2008 12:09 pm markdhc is a member here who would be happy to look after you.
look him up: http://forum.homeone.com.au/profile.php?mode=viewprofile&u=2310 http://www.DIYheating.com.au Re: Advice on gas ducted heating 9Dec 18, 2008 2:40 pm borg Your probably right when i check the price i assumed the unit contained the ducts etc but it doesnt. 1500 for unit. 250 per point X 7 plus return grill etc plus 1200-1500 to install so looks like over 4500 Borg, this gave me a clear picture what I have to pay for. Really appreciate your help. Re: Advice on gas ducted heating 10Dec 18, 2008 2:49 pm Ozfish, we used Australian Climate Systems to put gas ducted heating into our current place. They are in Lilydale. Jason was great to deal with, explained everything, good price and the installer cleaned up after himself. Great experience.
We are going to use them for our new build. Re: Advice on gas ducted heating 11Dec 18, 2008 3:42 pm Back Pocket Ozfish, we used Australian Climate Systems to put gas ducted heating into our current place. They are in Lilydale. Jason was great to deal with, explained everything, good price and the installer cleaned up after himself. Great experience. We are going to use them for our new build. Thanks BP. I will give them a call soon to find out more details. Re: Advice on gas ducted heating 12Dec 18, 2008 5:11 pm borg Just a a quick look. If you want to add refreidgerated cooling through the same system (ie same ducts) Beware of using the same ducts for both systems: http://forums.envirotalk.com.au/index.p ... topic=8182 Re: Advice on gas ducted heating 13Dec 18, 2008 8:12 pm dymonite69 borg Just a a quick look. If you want to add refreidgerated cooling through the same system (ie same ducts) Beware of using the same ducts for both systems: http://forums.envirotalk.com.au/index.p ... topic=8182 Thanks dymonited69 for the heads up. One word could save me hundreds bucks! Re: Advice on gas ducted heating 14Dec 18, 2008 8:47 pm sorry dynamite, you are confusing (AC= Aircond = refridgerated) with evapurotive cooling. Yes evaperative coolers need bigger ducts. But refridgerated you can use the same ducts as heating but they usually use higher r rating ducts ie higher quality. Re: Advice on gas ducted heating 15Dec 18, 2008 10:15 pm borg sorry dynamite, you are confusing (AC= Aircond = refridgerated) with evapurotive cooling. Yes evaperative coolers need bigger ducts. But refridgerated you can use the same ducts as heating but they usually use higher r rating ducts ie higher quality. Ahh I see. So if my evap AC ducts were better insulated then could I use them for heating as well? Re: Advice on gas ducted heating 16Dec 18, 2008 10:26 pm Just to say - I would never install ducted heating again... it gives the dustiest environment ever.
Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Advice on gas ducted heating 19Dec 19, 2008 8:38 am EcoClassic Just to say - I would never install ducted heating again... it gives the dustiest environment ever. Ed True. It needs constant maintenance. http://www.airfix.com.au/2.html Re: Advice on gas ducted heating 20Dec 19, 2008 8:41 am No they just need to be smaller.
Evap if you notice work with huge air flow so much so you even have to have your windows open. Also for Evap ducts are placed in centre of room. For heating and Refridge the ducts are at the external walls then you have air intake at the centre. So basic evap always need to be on its own. It works differently. Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6304 |
