Browse Forums Heating, Cooling & Insulation 1 Dec 12, 2008 6:28 am There seems to be a lot of wall vents in the 1930 bungalow I just bought. I am concerned that in winter we could lose a lot of heat through them. What are the ramifications of sealing them up?
I read somewhere that I will need them if I use the gas heaters that are in the house, but eventually we will move to ducted heating. Can I at least minimise the air flow through them? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Old House wall vents 2Dec 12, 2008 6:55 am We lived in an Edwardian for 15 years. No issues with heat loss through vents - DH measured air temperature at floor level, head height & ceiling level & there was plenty of heat at ceiling level.
Our place was f/brick - is yours ? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Old House wall vents 4Dec 12, 2008 8:09 am Helyn Didn't seem any problem with heat loss, although we didnt do a controlled experiment like Southies. Doesn't quite sound like a controlled experiment. You need to compare sealed and unsealed with similar weather. See if the heating needs to be left on for longer. Air leaks can result in up to 25% increase in heating bills. We put weather seals in door and windows and lowered our gas bill by about 20%. The vents in old style houses were used in the days of low efficiency fireplaces. You would otherwise poison yourself with carbon monoxide. Not so much an issue now with combustion stoves. Re: Old House wall vents 5Dec 12, 2008 10:52 am dymonite69 Helyn The vents in old style houses were used in the days of low efficiency fireplaces. You would otherwise poison yourself with carbon monoxide. Not so much an issue now with combustion stoves. Good input people, thanks. Thats what I am thinking dynomite. So the vents are there purely to vent the air inside the rooms....not the air between the double bricks? Re: Old House wall vents 6Dec 12, 2008 11:16 am Colsy So the vents are there purely to vent the air inside the rooms....not the air between the double bricks? I would check with a builder but the principle should be the same as a brick veneer structure. The cavity is in continuity with the roof space. It forms the drainage plane for condensation which exits the weep holes through the exteral leaf. retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13773 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8070 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 |
