Browse Forums Heating, Cooling & Insulation 1 Dec 09, 2008 8:59 am Hi All,
Has anyone had the problem when a ducted heating starts up it blows cold air first 20-30 seconds and then warm air comes? I spoke to the heating company and they explained to me that this happens because cool air in the ducts comes out first. Can this be fixed? Thanks, Anton Re: Ducted heating blows cold air first 20-30 seconds. 2Dec 09, 2008 9:38 am I don't think that could be fixed. I'd expect it to blow out cold air for the first 20-30 seconds. It's the same with airconditioning, why would it be different for heating? It's not like the ducts are heated. Re: Ducted heating blows cold air first 20-30 seconds. 3Dec 10, 2008 2:02 pm Antoxa I spoke to the heating company and they explained to me that this happens because cool air in the ducts comes out first. Unless they invent a device like they do for hot water where you use another pipe run to recirculate cold air back to the unit until a thermostat triggers a damper to route it out the vents. I would put up with the cold air. If you don't like a short sharp burst, put it on a low fan setting until it gets cranking. Re: Ducted heating blows cold air first 20-30 seconds. 4Dec 14, 2008 7:06 am Anton - with older units and 3 star units this is quite common. As soon as the heater gets the signal to turn on the fan starts and the burners fire up. However it takes about 30sec to 1min for the heater to warm up thus delivering warm air not cold air.
New units like the brivis ME and HE series actually start the burners first, wait until the temperature of the air gets to 50celcius and THEN start the fan, meaning no cold air blowing into the home - only warm air. Cheers Dynamic Heating & Cooling - http://www.DIYheating.com.au DIY Ducted Heating & Cooling Systems DIRECT to the public Re: Ducted heating blows cold air first 20-30 seconds. 6Dec 14, 2008 5:23 pm with mine.. it waits till it heats up before pushing the air through. Ours is a brivis unit and we are in a townhouse that is only about 4 years old. Re: Ducted heating blows cold air first 20-30 seconds. 7Dec 14, 2008 5:30 pm markDHC Anton - with older units and 3 star units this is quite common. As soon as the heater gets the signal to turn on the fan starts and the burners fire up. However it takes about 30sec to 1min for the heater to warm up thus delivering warm air not cold air. New units like the brivis ME and HE series actually start the burners first, wait until the temperature of the air gets to 50celcius and THEN start the fan, meaning no cold air blowing into the home - only warm air. Cheers We have the in ceiling ME from Brivis and it is great.... It ramps up slowly and the Air is warm from the start. Very impressed with this unit. Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6304 |
