Browse Forums Heating, Cooling & Insulation 1 Jan 18, 2007 12:28 pm What are peoples' thoughts on heat coming from the roof or the floor. Any noticable difference? Conversely, what about cooling from the floor vents?
The reason I'm asking is that I'd like to have both the cooling and heating coming from the same ducts so as to save costs. Thanks ! Re: Heating ducts, roof or floor does it really matter? 2Jan 18, 2007 5:20 pm Thats the whole point of ducted reverse cycle - they come from the same vents. As far as I've seen, if its possible to go under the floor then thats the way to go. Re: Heating ducts, roof or floor does it really matter? 3Feb 21, 2007 7:13 am Nowadays it doesn't really make too much difference. The ceiling vents used today help to move the air where it needs to go, units are built with much more air than the used to be. I would suggest ducted r/c a/c through the ceiling, or ducted heating with add-on air conditioning to go through the floor. With that said, both systems can work either way around with no adverse effect. Dynamic Heating & Cooling - http://www.DIYheating.com.au DIY Ducted Heating & Cooling Systems DIRECT to the public do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28281 thanks guys! yes this is how I've exactly raised it with the builder. still awaiting response. 12 6044 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16554 |
