Browse Forums Heating, Cooling & Insulation 1 Sep 23, 2024 11:14 am Hi, We're building with a volume builder, and added provisions for ceiling fans. The house is ducted aircon, and the outlets are located "as selected by the installers on site" (i.e. we had no input into their location which is probably for the best, since we have no idea where they are best located). The outlets have mostly been installed near the centre of the room, either above where the fan blades will be, or just outside the arc of the blades. We were looking at Calibo Cloudfans, but their install guide explictly requires 1.5m clearance from the tip of the blade to the aircon outlet or you'll void your warranty. No other manufacturers we've looked at appear to have this requirement. Could you share your experiences if you have installed ceiling fans close to aircon ducts ? what's the rationale on this? In my mind, the risk weepholes mitigate isn't solved by acrylic render. 9 36839 Many thanks for your reply. Yes I am concerned with the work done. I have another problem with my contractor and I hope this next investigation and review with the… 2 14722 Curtain Ceiling Track Installation Advice? With the last 20cm of the ceiling track on an angle, could it be as simple as: 1. Bending the track slightly to match the… 0 14947 |
