Browse Forums Heating, Cooling & Insulation 1 Nov 02, 2008 10:38 am Hi - we are building a new extension consisting of new kitchen, bedroom, study, bathroom, laundry and family room. We are at frame stage and I want to install "something" between the internal wall studs before the plaster goes in to provide some form of sound proofing. I'm looking for links or product names and suppliers. I've done a search on the forum with no luck, and also asked Bunnings and they don't stock anything like that.
Any suggestions? Re: Sound proofing new internal walls 2Nov 02, 2008 1:00 pm The best soundproofing batts are rockwool, but they're quite pricey. The cheapest options're Gold or Pink glasswool batts. See http://www.insulation.com.au/catalogue.htm and http://www.bradfordinsulation.com.au/Pr ... -wall.aspx
Search for: Glasswool SUPERTEL, Rockwool FIBERTEX 350, ACOUSTICLAD Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Sound proofing new internal walls 3Nov 02, 2008 1:17 pm You can also get polyester batts like Autex QuietStuf, probably not as good but a nicer product to work with.
Just make sure you get the appropriate thickness for your studs, squishing batts in reduces their effectiveness. Even using plain R1.5 polyester insulation has muffled the sound a bit in our house. As you said, the main point is to at least put "something" in the walls. Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20855 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16526 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7612 |
