Browse Forums Heating, Cooling & Insulation 1 Nov 25, 2023 9:33 pm Hi everyone, Hoping I might be able to ask for some assistance. I've moved into a new off the plan townhouse about 7 months ago. I ended up buying a VEVOR Infrared Thermal Imager Thermal Camera IR Resolution 240x180. I took some thermal camera photos of the ceiling on the second floor when it was raining throughout this week. I'm not sure how to interpret them but it looks like the camera recognises moisture? Here are some examples below. Is this normal or does it point to potential water leaks? Appreciate any help. Cheers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ 1 comment ⋅ Pin to Ideaboard ⋅ Re: Opinion about Ceiling Moisture 2Nov 26, 2023 1:56 am If i remember correctly from another video on youtube the moisture is showing up as blue area . Google it see what you can find b unit I am sure the inspector said the blue area is moisture in the walls and under floor tiles but his equipment is very high end. Good luck. Re: Opinion about Ceiling Moisture 3Nov 26, 2023 9:11 am You really need to use a moisture meter in conjunction with a thermal camera. Remember, the thermal camera is only measuring differences in temperature - it's entirely possible some areas are just colder than others (especially when its just a few degrees difference). Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 2915 Building Standards; Getting It Right! Hi everyone, a contractor build a "retaining wall" for me and after 3 months there was a crack. They "repaired" the crack by adding an expansion joint where the crack… 0 2109 |
