Browse Forums Heating, Cooling & Insulation 1 Oct 24, 2008 11:16 am Hi all.
This question probably gets asked every 2nd day, but we're about to get our air con/heating sorted. We're going with a ducted system, with 4 zones to do our cooling and heating. From the quotes we have got there are 3 different systems we could use, all single phase. 1) Mitsubishi Inverter 2) ActronAir digital scroll 3) Daikin inverter (FDYQ160K 15.5kW) I have no idea which are good and which are bad. All the brochures say they're all good. But does anyone have an opinion on which might be the better one of the 3? Thanks in advance for any information people might have. Cheers, Pete viewtopic.php?f=38&t=8824 Re: Another which ducted air con to use thread 2Oct 24, 2008 9:05 pm daikin out of that bunch - but the actronair digitial scroll is also a very good unit
however keep in mind that electric heating can be very expensive, particularly here in melbourne. A lesser known but very effective alternative is gas ducted heating with add-on air-conditioning. All the benefits environmentally and with running costs of running a gas ducted heater, with the ultimate in cooling - refrigerated. All built into one system. If you need a new heating and cooling system IMHO that is they way to go. All the electric a/c units will say they are 200% or 400% efficient - they are - but still not even close to gas when it comes to running costs when heating. Cheers, Mark Dynamic Heating & Cooling - http://www.DIYheating.com.au DIY Ducted Heating & Cooling Systems DIRECT to the public Re: Another which ducted air con to use thread 3Oct 25, 2008 12:24 pm PeterH Hi all. This question probably gets asked every 2nd day, but we're about to get our air con/heating sorted. We're going with a ducted system, with 4 zones to do our cooling and heating. From the quotes we have got there are 3 different systems we could use, all single phase. 1) Mitsubishi Inverter 2) ActronAir digital scroll 3) Daikin inverter (FDYQ160K 15.5kW) I have no idea which are good and which are bad. All the brochures say they're all good. But does anyone have an opinion on which might be the better one of the 3? Thanks in advance for any information people might have. Another vote for Daikin... Re: Another which ducted air con to use thread 6Mar 17, 2009 10:45 am We ended up going with the Actron. Main reason we picked it was because it could be ramped down (is that the right term?) a lot more than the others. It was only hooked up yesterday so we haven't used it yet. Cheers, Pete viewtopic.php?f=38&t=8824 Re: Another which ducted air con to use thread 7Mar 17, 2009 6:14 pm ActronAir is much cheaper to run and more efficient
and an EXCELLENT unit! Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Another which ducted air con to use thread 8Mar 17, 2009 10:27 pm i picked a fujitsu unit personally just to throw something else in the mix
in reality surely they would all perform quite similarly you would think Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Another which ducted air con to use thread 9Mar 18, 2009 1:19 pm That's what I like to hear pinkfairymagic. Thanks!
Looking through all the brochures and talking to people its hard to see how they differ, apart from prices I guess. Bit of a lottery picking the right one. Hopefully we did ok. Cheers, Pete viewtopic.php?f=38&t=8824 Re: Another which ducted air con to use thread 11Apr 22, 2009 9:04 pm *Subscribing* My partner wants a Daikin because it can be easily hooked up to c-bus :S But if others are more efficient then.... that changes things Re: Another which ducted air con to use thread 12Apr 23, 2009 11:57 am We are looking at ducted air con. our house is 30sqm. and looking at 6 - 7 zones. We have 3 phase connected Anyone with similar and whats your thought and what did you end up getting? Also some one told me its only about $1500 - $2000 to get gas heating hooked into it? Re: Another which ducted air con to use thread 13Apr 23, 2009 12:42 pm slegger10 We are looking at ducted air con. our house is 30sqm. and looking at 6 - 7 zones. We have 3 phase connected Anyone with similar and whats your thought and what did you end up getting? Also some one told me its only about $1500 - $2000 to get gas heating hooked into it? Is that all??!!! If it's that much I might consider it for sure. Re: Another which ducted air con to use thread 14Apr 23, 2009 1:26 pm quote from whirlpool below "The TCO is cheaper to have a reverse-cycle than adding a gas heater extra. I got a quote to install a gas heating and it required extra a few grand to add. That's not correct. From the link below even the worst efficiency gas ducted systems out perform an average three star reverse cycle ducted system. ~$580 per year v's ~$760 Now most gas ducted systems are 4-5 star the gas cost can be reduced further to ~$440. Assuming you had a four star R/C ducted system you'd still have costs proportionally higher than gas." I know its only a reversing valve in the A/C being a tigh *** can i save money in not getting a reverse cycle A/C and just get the ducted gas heating installed? Re: Another which ducted air con to use thread 15Apr 24, 2009 1:07 pm slegger10 We are looking at ducted air con. our house is 30sqm. and looking at 6 - 7 zones. We have 3 phase connected Anyone with similar and whats your thought and what did you end up getting? Also some one told me its only about $1500 - $2000 to get gas heating hooked into it? Here's a comparison for you. We are building 30 sqr home (living only) we are putting in an Actron Air ESP Plus unit, 24kwts and it comes with 8 zones 13 outlets and installed costing $17k (in a very rural area) This unit is refridgerated cooling and heating all in one! Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Another which ducted air con to use thread 16Apr 26, 2009 5:00 pm We were told that getting parts for Actron was far quicker than for Daikin - days as opposed to a few weeks. Does anyone know if this is true? Is there generally a longer wait time for ordered parts for Daikin? Re: Another which ducted air con to use thread 17Apr 28, 2009 4:36 pm purpleninja We were told that getting parts for Actron was far quicker than for Daikin - days as opposed to a few weeks. Does anyone know if this is true? Is there generally a longer wait time for ordered parts for Daikin? Actron is locally made and supported (QLD). I have the Livezi which is the same system essentially, just a different badge. In heating mode it barely ever raises beyond 30% heating capacity. I have a ~38sq house Re: Another which ducted air con to use thread 18Apr 28, 2009 4:45 pm pasey25 Actron is locally made and supported (QLD). I have the Livezi which is the same system essentially, just a different badge. In heating mode it barely ever raises beyond 30% heating capacity. I have a ~38sq house Thanks for the info ... it's nice to have reassurance Re: Another which ducted air con to use thread 19Apr 28, 2009 4:51 pm pasey25 purpleninja We were told that getting parts for Actron was far quicker than for Daikin - days as opposed to a few weeks. Does anyone know if this is true? Is there generally a longer wait time for ordered parts for Daikin? Actron is locally made and supported (QLD). I have the Livezi which is the same system essentially, just a different badge. In heating mode it barely ever raises beyond 30% heating capacity. I have a ~38sq house What size is your unit? We have a quote for 18kw unit but the installer says that 14kw will be used in out open plan family, kitchen, rumpus area. It it does have cathedral ceilings up to 4.5m. Hove you been able to heat the whole house when you come home from work. My house is about 30sq and we live in Melbourne. Re: Another which ducted air con to use thread 20Apr 28, 2009 5:06 pm astroboy pasey25 purpleninja We were told that getting parts for Actron was far quicker than for Daikin - days as opposed to a few weeks. Does anyone know if this is true? Is there generally a longer wait time for ordered parts for Daikin? Actron is locally made and supported (QLD). I have the Livezi which is the same system essentially, just a different badge. In heating mode it barely ever raises beyond 30% heating capacity. I have a ~38sq house What size is your unit? We have a quote for 18kw unit but the installer says that 14kw will be used in out open plan family, kitchen, rumpus area. It it does have cathedral ceilings up to 4.5m. Hove you been able to heat the whole house when you come home from work. My house is about 30sq and we live in Melbourne. ours is 18kw in a ~38sq home i slightly underspecced. Down stairs rarely needs cooling as it is part underground (theatre). the house heats up fine, although we never activate every zone. At the moment there's only 2 of us so we usually heat the living area and the bedroom. Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6304 |
