Browse Forums Heating, Cooling & Insulation 1 Dec 27, 2021 10:37 am Hi Guys I am thinking of converting my garage(28m2) to a room (adding insulation/flooring etc). I will need to install an AC in the garage. I wanted to look at extending our existing ducted aircon( carrier 5.5kw system) and add garage as an additional room to an existing zone. Is this an option to consider or I will need to go with a split system just for the garage? If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5494 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1673 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 7978 |
