Browse Forums Heating, Cooling & Insulation 1 Nov 22, 2021 1:20 pm Has anyone had experience with a west-facing window in the ACT? Is it that bad in summer over here? I've been told that it adds volume to our design - the design already has floor-to-ceiling north-facing windows. This window essentially curves around and extends the north-facing one. The west-facing window will be floor-to-ceiling as well. Re: West facing window in Canberra 2Nov 22, 2021 4:22 pm antler Has anyone had experience with a west-facing window in the ACT? Is it that bad in summer over here? I've been told that it adds volume to our design - the design already has floor-to-ceiling north-facing windows. This window essentially curves around and extends the north-facing one. The west-facing window will be floor-to-ceiling as well. Also, we have a northern wall of glass too. Just be sure that you have the suitably sized eaves, and something to shade the early morning easterly summer sun, which can heat your house at the start of the day. Re: West facing window in Canberra 3Nov 22, 2021 5:25 pm arcadelt antler Has anyone had experience with a west-facing window in the ACT? Is it that bad in summer over here? I've been told that it adds volume to our design - the design already has floor-to-ceiling north-facing windows. This window essentially curves around and extends the north-facing one. The west-facing window will be floor-to-ceiling as well. Summers can be pretty fierce in this area (I live near Cooma, just down the road), so unshaded west facing windows are best avoided. In our custom design, we have no west facing windows at all, but still get a bit of westerly sun in our southern windows because our orientation is not exactly north (15° east actually). We have had to strategically plant a tree to help out. Also, we have a northern wall of glass too. Just be sure that you have the suitably sized eaves, and something to shade the early morning easterly summer sun, which can heat your house at the start of the day. Thanks arcadelt! That's really useful to know. We'll remove the west-facing window. It was going to be un-shaded (and without any curtins!). The energy assessor has recommended some form of eaves between the (multi-level) north-facing wall of glass. Re: West facing window in Canberra 4Nov 22, 2021 7:07 pm antler The energy assessor has recommended some form of eaves between the (multi-level) north-facing wall of glass. Absolutely: if you have floor to ceiling windows on a multi-story property, you will definitely want awnings or outriggers over the ground floor windows. Is this a custom build being designed by an architect or building designer? If so, their drafting software should be able to show you exactly how the sun will enter your property at any day and time during the year. This will give you a visual indication if the solar-passive aspects of your build are correct. Re: West facing window in Canberra 5Jan 23, 2022 11:01 pm arcadelt antler The energy assessor has recommended some form of eaves between the (multi-level) north-facing wall of glass. Absolutely: if you have floor to ceiling windows on a multi-story property, you will definitely want awnings or outriggers over the ground floor windows. Is this a custom build being designed by an architect or building designer? If so, their drafting software should be able to show you exactly how the sun will enter your property at any day and time during the year. This will give you a visual indication if the solar-passive aspects of your build are correct. It is! I'm sure it does, but we've been given little feedback on it. I've been doing my own research using solar-path modelling. Removing that west-facing window has been quite helpful in getting the EER up (despite the increase in size of the house). It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 15524 Wow I hadn't realised things had gotten that pricey in just a couple of years since I built, that is crazy with how much land is now costing if you aren't lucky enough to… 3 5335 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 12589 |
