Browse Forums Heating, Cooling & Insulation 1 Aug 05, 2021 9:36 pm Hi All I have got Daikin 6KW Model FTXF60TVMA split system with WiFi Adapter model BRP072C42 I managed to connect WiFi to my home router means I can use app on my iPhone to access the adapter hence I can turn on and off Daikin The app has a section where you can access your air condition when you are outside home means using internet and to do so the app asks you to create a credential (username and password),,,,so far I created 5 (FIVE) usernames and 5 password and when I tried to login it says : The login or password is incorrect https://imgur.com/a/2XQzCF4Thx Thx Re: Daikin WiFi adpter can't access it from outside home 2Aug 12, 2021 12:02 pm Hi Zillah The image link doesn't work. Can you try to fix that so we can see the error? Have you tried setting up the app on another phone and connecting from there? If the air-conditioner is connected to your wifi and you don't have any other firewall restrictions, it should work easily. Have you spoken to Daikin about this issue? For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9237 The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17204 |
