Browse Forums Heating, Cooling & Insulation 1 Mar 21, 2021 1:23 pm Hi everyone, this is my first post. I've recently purchased a home where the prior owners have had some sub-standard work done in the past. The pipework in the photos is the hot water feed from the solar panels down to the hot water tank. It looks like the copper pipe has been routed quite strangely, and has been bent to the point the pipe has constricted. I want to get this re-done so I can apply some new cladding on the soffits and it seems the best thing to do would be the pipe re routed behind the soffit. Thoughts?! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5877 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17539 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10465 |
