Browse Forums Heating, Cooling & Insulation 1 Jan 17, 2021 6:45 pm We are planning to put 5Kwh Mitsubishi Avanti series on top of our sliding glass door. The electrician said that there might be steel on top of the sliding glass door that might block the installation. Can anyone help, how long usually that steel is? is 48 cm space on top of the sliding glass door enough for the 5Kwh system? Image is below: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have lookup the spec of the aircon and it has 30cm height. Any suggestion will be much appreciated. Thank you in advanced Re: Is this space enough to put a 5Kwh Aircon? 2Jan 18, 2021 7:14 pm If the outside is brick, you will have a steel lintel. It should be hard against the bricks and maybe 6mm thick. What will prevent the install is no space below to run the pipe work. The bend radius for pipe is 100mm and drainage should flow down. Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5363 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15773 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13744 |
